Which way is on
bluejlewis21
Member Posts: 2
What does it say under the handle?0
Looks like it says "ON" under the handle.0
Oh and there is a screw in the back or something like that that lets you move the stop on the right to a different hole so you can set it to match the emitter so it doesn't put steam in the returns?DanHolohan said:Yes, it’s a throttling valve. Those holes probably indicate levels of heat, typically, each space equals 10 square feet of EDR. Turning it clockwise should close it.
