Gurgling Radiator
Full_Disclosure
Member Posts: 5
My daughter lives on the third floor of a very old home.
The heating guy came to get the system ready for the season, and left off one radiator which had, prior to his arrival, been turned completely off.
After a few days, daughter got cold enough to need it turned on (it is one of about three in a large room), and did so. The rest of the system, throughout all floors of the home, had been running.
The gurgling sound, like a percolator at the end of its boil, annoys her, and is a bit pronounced. It only happens with this radiator, the one which had been in the off position.
Is there anything which can be done to remedy this without calling the workman back?
Thanks.
Thanks.
More than likely either the radiator or some of the piping to it is not pitched correctly. It looks like you have a two-pipe system with both pipes connected to the same end of the radiator. If you have a level check the pitch of the radiator it should be slightly lower on the end with the two pipes, If the pitch is wrong you can raise the far end slightly with a pry bar and some wood blocks and shim the two legs up a small amount 1/8-1/4"
Also can you take a picture of the boiler and it's controls? What pressure does the boiler run at if any? Does the rest of the house heat with no issues?1 -
Thank you!
I hadn't even taken note pf the two pipes.
I will photograph from a distance so you can see what I am going to describe next.
Two of the radiators stand very near each other and drain down into the same pipes.
The leftmost radiator is indeed pitched with the pipe inlet side a little lower, just slightly aboe to be seen if that is what one is looking for.
The rightmost radiator is less noticeably so, and the level reading tells me the degree of pitch from inlet-side to its other end is truly best described as a negligible pitch. (It is this one which makes the gurgle.)
Unfortunately, there is no way to answer those other questions without engaging the homeowner, and better left undone at this point.
Thank you.
I wonder.... if this is steam, I wonder if those two radiators tie together under the floor and the drop to somewhere? If that is so, I wonder if they tie with the supply or drain, as the case might be, arranged as the two sides of the top of a T, and the pipe down from the leg? And if that is so... then one side or the other has a slightly bad pitch, and might well gurgle...Br. Jamie, osb
Hot water system and top floor. The system pressure needs to be increased or the radiator needs to be bleed ,of air ( bleeder top far side of radiator). Down by the boiler there will be a boiler feed valve which adjusts the system pressure . It needs to be turned on or adjusting ... 12#-15#
Hot water?? Has the radiator been bled?Br. Jamie, osb
Jamie Hall...I think I understand the litany of things you are placing into consideration.
'...I wonder if they tie with the supply or drain, as the case might be, arranged as the two sides of the top of a T, and the pipe down from the leg? And if that is so... then one side or the other has a slightly bad pitch...."
This is my best guess, but just a guess.
Thank you.0 -
Big Ed_4
Thank you for that detail on the bleeder valve...for some reason I could not see it!
If it becomes an untenable situation, I can ask someone to help.
Simple requests have been received as antagonistic by property owner, unfortunately.
The psi info will be something I can only hope the serviceman, should he be called out, is adept at determining.
Thanks.
Mad Dog_2
Oh, had no idea every radiator was not a steam radiator. My error.
Thank you.0
- 50 Industry Classes
