Nauseous Smell
Have Buderus Propane 142 boiler, 17 years old.  Radiant house floor heat.  It originally wouldn’t start.  Thermostat OK.  Cleaned heat exchanger fins.  Reassembled it.  Still wouldn’t ignite, igniter glows. I then ordered a gas valve with fan from ebay. Installed it and it ignited.  But now the smell in the house is harsh.  The vent vapors outside are even worse.  It heats the house OK.  We bought 2 carbon monoxide sensors and mounted one in the utility room where the boiler is mounted and one in the adjacent laundry room.  They both alarmed shortly after boiler fired off.
Any suggestions?
Thank you, Bill Kelly
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,994
    Hi @WCKjr123 , Don't fire up the boiler again! It's clearly unsafe. You need to get a technician in who has a combustion analyzer. Let that person adjust and clean things up. Propane can soot up quickly and mess with the draft and combustion. Others here will have more to say, but you might check "find a contractor" on this site and see if anyone is close to you.
    Yours, Larry
    PC7060Erin Holohan HaskellWaher
    pecmsg Member Posts: 6,740
    Shut it down!
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,372
    Lock 🔐 it out..Power off. Gas valve off.  Its DONE!!!  You need a new boiler.  Whatever it costs...its cheaper than a Funeral!  Mad Dog 🐕
