Anyone try using orifices instead of steam traps?
I came across this article and wondered if anyone tried using orifices in the steam supply instead of traps. If so, how did it work? Thanks I am sort of intrigued by it
Ray Wohlfarth
Boiler Lessons
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,491
    In the past..very cool 😎. My buddy Bill Traube Licensed Master Plumber from Sea Cliff Long Island Gold Coast...showed me how to make them out of silver coins...that he would drill out.  Bill Got The Heck out of Dodge (Long Island 🏝)  with his wife and 5 Kids..Gotta be pushing 68ish...Moved to Fredrick Maryland.  Boy do I miss that guy...Great plumber, Heating man. He was a local Legend. Quite a few of the plumbing inspectors didn't like him because he often knew the code better than they did, did top notch work,, and would NEVER back down or relent..He once called out an inspector with his hand out in front of a whole construction site.
    "I don't give Payola..I don't take payola...$@#&%. !!!'
    They tried to punish Bill by not showing up to inspections, not calling him back..Bill was a Big Boy  6 foot 2  260lbs.  He went down to the Building Dept, walked behind the Counter and denounced everyone very loudly, the place was packed with Homeowners, Contractors & Expediters...Ha ha 😂 🤣 😆 Awkward!!!
    The Commisioner came out of his office, pulled Bill in his office &  had a private meeting with Bill, apologized and it never happened again.. He beat " City Hall!"  My man!  Bill was a fantastic Steam BEFORE 1992 Lost Art came out..AND he had a great test lab: "Sea Cliff is a Great Historic North Shore town with Old Victorians..Two-Pipe Vapor systems.
     Mad Dog
    CLamb
  • JUGHNE
    JUGHNE Member Posts: 11,536
    I came across Henry's article some years ago.
    I first used the orifices in a house that had most trap guts removed, went for 80% of EDR of CI rad.
    Had good success with that.
    Since then for several school buildings.
    You just have to keep the pressure within a certain window.
    I have since found a very expanded chart for pressure, EDR and sizing.
    Mad Dog_2
  • jumper
    jumper Member Posts: 2,516
    Yes and yes. After windows have been upgraded radiation is oversized so radiator condenses steam. Inlet orifice seems to throttle steam better than a normal valve does. Why I do not know.
    When replacing trap mechanism with outlet orifice then the hole has to accommodate both condensate and air. How much air?
    In the seventies commercial boilers were often replaced with multiple boilers and most of the time only 25% or 33% of capacity sufficed. I didn't hear about problems pushing air through system but I sometimes worried about it before falling asleep.
  • JUGHNE
    The inlet orifices' would control better than the typical hand valve because it is of a fixed size. The only changing factor could be the steam pressure.
    The hand valve can be adjusted but the temp changes seem to change the opening for the steam.....and also there are many hands to change the valve adjustment.
    I was concerned about the air removal from steam mains and would try to put a fair amount of air venting at the end of steam mains ahead of any F&T's.
    Between the orifice small opening and the seemingly restrictive air passage of F&T's, it seemed logical to increase the steam main venting.
    Mad Dog_2
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,946
    Thank you all. It seems like a cost effective idea
    Ray Wohlfarth
    Boiler Lessons
    Mad Dog_2
