What is this device
watchmaker
Member Posts: 2
This is a pic of a device that I believe to be a type of throttling valve depending on the radiator size but hopefully someone can confirm or explain what it is. It has a bolt and Asher’s under the bolt head which are loose. I assume a handle was broken off and replaced. Any help is appreciated. Thanks
Very likely. What does it say on the side of the body there?Br. Jamie, osb
I couldn’t actually read itJamie Hall said:Very likely. What does it say on the side of the body there?
Consulting1 -
- 50 Industry Classes
