What is this device
This is a pic of a device that I believe to be a type of throttling valve depending on the radiator size but hopefully someone can confirm or explain what it is. It has a bolt and Asher’s under the bolt head which are loose. I assume a handle was broken off and replaced. Any help is appreciated. Thanks
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    It may be ... I wouldn't touch it unless you have to....
    watchmaker
    Jamie Hall Member Posts: 27,311
    Very likely. What does it say on the side of the body there?
  • watchmaker
    watchmaker Member Posts: 2
    I couldn’t actually read it
    Steamhead Member Posts: 18,453
    @watchmaker , post a pic- we might recognize it.
    Consulting
    CLamb
  • Teemok
    Teemok Member, Email Confirmation Posts: 757
    A valve with a busted handle disguised so no one will try to turn it?
    watchmakerCLamb
