1903 Times Square Construction: Is the White Cladding Here Insulation? or Just Brick?
D107
Member Posts: 1,945
Looks like some kind of insulation--if so wonder what they would have been using then: asbestos?
Is that the "Flatiron Building"?All Steamed Up, Inc.
Consulting0 -
Supposed to be 1 times square0
If it isn't, it's a pretty close duplicate...Steamhead said:Is that the "Flatiron Building"?
It's the old NYTimes building, north of Flatiron by 15 blocks or so. Broadway created both buildings and the other triangle ones as it cuts at a small angle away from the N/S streets
It's the one that the New Year's ball is on!
https://en.wikipedia.org/wiki/One_Times_SquareNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
Any wall we ever opened in Commercial buildings in NYC Pre-WW II was void of any insulation..brick, block, Terracotta Block, cinder block....thats it. Pipe was almost always wrapped in Asbestos. Mad dog1
