TT Solo
Ironman
Ironman Member Posts: 7,849
One of my suppliers has two of these that are brand new at a deeply discounted price. Are there any known issues?
I haven’t installed one for a few years, but I never had any issues.
Bob Boan
  • kcopp
    kcopp Member Posts: 4,614
    If nothing else its a great deal just on the parts alone!
    Ironman
  • Ironman
    kcopp said:
    If nothing else it’s a great deal just on the parts alone!
    Exactly!
    Do you know of any issues or is it just being discontinued?
    Bob Boan
  • kcopp
    I installed a few. No issue I know of.
    Ironman
    HVACNUT Member Posts: 7,200
    I only service 1 of those boilers, and the only thing that was done besides normal maintenance was the display panel was replaced. You couldn't read it anymore. Other than that it's been fine the past 6 years I've been servicing it.
    I'm assuming at that price they're "as is".
    Do you get the warranty?
    Ironman
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Not sure,but I think this model had a "recall" ..
    It was an easy fix by adding a couple screws to the intake and exhaust ports on top of the boiler.
    I'd also check if it was affected by the "Ignition Upgrade"
    Ironmankcopp
  • GGross
    GGross Member Posts: 1,728
    edited November 2023
    Make sure that it has had the ignition upgrade performed on it! The PT series like the one shown required an ignition upgrade, it was offered at no charge for a while but now would need to be bought, without the ignition upgrade there is no replacement igniter available!
    Ironman
  • Ironman
    Yes, full warranty according to TT.
    Bob Boan
    HVACNUT
  • tim smith
    tim smith Member Posts: 2,886
    Pretty sure you have to do the recall for flue connector on these. Verify serial #. But you get 150 bucks appx for doing and takes all of about 15 minutes. Service many of them. Ok boilers, not too many problems.
    good luck
  • tim smith
    They don't happen to have any heat exchangers there pawning off do they? Especially psrkit44 aka parkit95 for a ps399.
  • GGross
    I would hope the wholesaler did the recall fix on the in stock inventory. As a distributor we were required to do the recall on anything in stock. We weren't allowed to sell the recall units without them being fixed first
  • Karl Reynolds
    Karl Reynolds Member Posts: 79
    Tim, you probably know this but the PSRKIT44 was discontinued about six years ago. The new replacement is the PARKIT95. These are not too hard to come by.
  • tim smith
    In my question I also put aka parkit95
