Recommend a thermostat to me
Turn off room sensing and put them in closets or the mechanical room. It's done all the time.
Or you can offer the 561 and let them play with the thermostats on their phones. That's always fun.0 -
This is a possible backup plan, and the way I would normally expect houses like this to be set up. They seem pretty set on thermostats in each zone though so I am on the hunt for some options.HVACNUT said:Turn off room sensing and put them in closets or the mechanical room. It's done all the time.
I have gutted out the circuit board with display, painted the edges of mount plate and front cover with flat black enamel then put board back in. Board is either mounted to case with push pins or screws. Works great, Done it with Vision pro thermostats also. More than 1 way to skin a cat. Does not take long either. You may have to scrape off the paint on the plastic front cover where the soft up & down arrows go through front cover so they dont stick to the openings in front cover when pushed. Good luck.2
The black thermostat I'm using,it's a color touchscreen wifi thermostat. https://www.breezecontrols.com/wired-thermostat.html1
Only option is Celsius? I'd have to hang a conversation chart next to it.CAROLYANG said:The black thermostat I'm using,it's a color touchscreen wifi thermostat. https://www.breezecontrols.com/wired-thermostat.html
Otherwise it looks nice.0 -
Only option is Celsius? I'd have to hang a conversation chart next to it.HVACNUT said:CAROLYANG said:The black thermostat I'm using,it's a color touchscreen wifi thermostat. https://www.breezecontrols.com/wired-thermostat.html
It can choose ℉ or ℃0 -
^^^^^^^^^^^^^^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^MikeAmann said:T2/images/I/51krRihwrcL._AC_UF894,1000_QL80_.jpg" alt="" />
Rustoleum 2X spray paint works on plastics.tim smith said:I have gutted out the circuit board with display, painted the edges of mount plate and front cover with flat black enamel then put board back in. Board is either mounted to case with push pins or screws. Works great, Done it with Vision pro thermostats also. More than 1 way to skin a cat. Does not take long either. You may have to scrape off the paint on the plastic front cover where the soft up & down arrows go through front cover so they dont stick to the openings in front cover when pushed. Good luck.
See my sight glass boiler videos: https://bit.ly/3sZW1el3
- 50 Industry Classes
https://www.youtube.com/watch?v=O4irXQhgMqg
