Recommend a thermostat to me
Hello I have a job going with many Tekmar 519 thermostats. These are simple heat only thermostats for in floor heating that come with a floor sensor. The homeowner has decided they do not like the white color thermostats, so I am looking for something heat only that is a black color and might be a good fit for a radiant floor. Bonus points if it accepts a floor sensor as I do believe they already have these floor sensors installed but it is not required
    HVACNUT Member Posts: 7,526
    Turn off room sensing and put them in closets or the mechanical room. It's done all the time.
    Or you can offer the 561 and let them play with the thermostats on their phones. That's always fun.
  • GGross
    GGross Member Posts: 1,972
    This is a possible backup plan, and the way I would normally expect houses like this to be set up. They seem pretty set on thermostats in each zone though so I am on the hunt for some options.
  • tim smith
    tim smith Member Posts: 2,935
    edited November 2023
    I have gutted out the circuit board with display, painted the edges of mount plate and front cover with flat black enamel then put board back in. Board is either mounted to case with push pins or screws. Works great, Done it with Vision pro thermostats also. More than 1 way to skin a cat. Does not take long either. You may have to scrape off the paint on the plastic front cover where the soft up & down arrows go through front cover so they dont stick to the openings in front cover when pushed. Good luck.
    hot_rodGGross
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Paint them :smiley:
    lobucethicalpaulEdTheHeaterMan
  • lobuc
    lobuc Member Posts: 14
    Lux Kono is a decent stat and you can get a variety of colored faceplates. No floor sensing and it can be set up and used with wifi or not. Can be a little tricky to set up wifi but after you do 1 or 2 not too difficult.
    GGross
  • CAROLYANG
    CAROLYANG Member Posts: 2
    The black thermostat I'm using,it's a color touchscreen wifi thermostat. https://www.breezecontrols.com/wired-thermostat.html
    GGross
    Only option is Celsius? I'd have to hang a conversation chart next to it.
    Otherwise it looks nice.
    GGross
  • CAROLYANG
    It can choose ℉ or ℃
    GGross
    Ok. I didn't see that in the literature. Just said Celsius.
  • Intplm.
    Intplm. Member Posts: 3,083
    MikeAmann said:
    T2/images/I/51krRihwrcL._AC_UF894,1000_QL80_.jpg" alt="" />
    Rustoleum 2X spray paint works on plastics.
    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    ethicalpaul Member Posts: 8,931
    EdTheHeaterManWMno57Intplm.
