Building Engineer's attempt to stop a leak
In your heading, you used the term "building engineer". You don't mean that he was a licensed building engineer do you. If he was attempting to stop a leaking joint, there are much better ways. I would take away his license and give him a broom and dust pan. That said, please answer the question as to what he was trying to accomplish.1
retiredguy said:In your heading, you used the term "building engineer". You don't mean that he was a licensed building engineer do you. If he was attempting to stop a leaking joint, there are much better ways. I would take away his license and give him a broom and dust pan. That said, please answer the question as to what he was trying to accomplish.1
Not a fire man or stationary engineer. This person works for the state. Having a pulse is the only requirement for the title. He was trying to accomplish and succeeded at doing the bare minimum.HydroNiCK said:
Got him through his shift.1 -
pecmsg said:Got him through his shift.0
Someone from "The State"? Which state?
I happened to know that State employees from certain states are exempt from a degree or a license in the field they are in. This opens up a big can of worms in so many instances that I have personally experienced.
@HydroNiCK if you dont mind? What state? Your pic above is yet another example.0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
