Big Mouth steam trap?
So I have some very old main vents on my single pipe steam system and one is spitting water. I did some calculations, and bought a Gorton 1a for the short run, and needed 2 Gorton #2's for the long run, so opted to buy a Big Mouth. The old vents are stuck pretty good, and I'm afraid of cracking the pipes, so while I was having a tech do my boiler maintenance, I asked if he would replace the vents. He wouldn't install my vents (only hoffman 75's that they would provide), but he told me the Big Mouth wasn't a vent, but rather a steam trap, and wasn't appropriate for venting a single pipe main.
They seem like common recommendations here, so wanted to ask your opinions on what he said? thanks in advance.
  • ChrisJ
    ChrisJ Member Posts: 17,341
    The Big Mouth is a trap that was converted into a vent for steam systems, including single pipe systems.
    It's intended purpose is to be used as an air vent on steam systems including single pipe systems.
    CLambsandselz
    ethicalpaul Member Posts: 8,725
    I wouldn't let a tech like that back in my house.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,587
    The big mouth is designed precisely for your application. There is a bit of debate here on the wall about their reliability.
    ethicalpaulsandselz
    109A_5 Member Posts: 3,950
    Hello @sandselz,
    Works for me. I like that you can take it apart and repair it, if needed.
    sandselz
    EBEBRATT-Ed Member Posts: 20,137
    Some companies have a rule about only installing parts that they provide.
  • Neild5
    Neild5 Member Posts: 203
    I have had to replace the o-rings on 4 of mine when they started leaking.  They were all from early batches, the o-rings were not the same as what are on the more recent ones I added to the system.
    I’m sure they do! I have some rules too
