Big Mouth steam trap?
They seem like common recommendations here, so wanted to ask your opinions on what he said? thanks in advance.
The Big Mouth is a trap that was converted into a vent for steam systems, including single pipe systems.sandselz said:So I have some very old main vents on my single pipe steam system and one is spitting water. I did some calculations, and bought a Gorton 1a for the short run, and needed 2 Gorton #2's for the long run, so opted to buy a Big Mouth. The old vents are stuck pretty good, and I'm afraid of cracking the pipes, so while I was having a tech do my boiler maintenance, I asked if he would replace the vents. He wouldn't install my vents (only hoffman 75's that they would provide), but he told me the Big Mouth wasn't a vent, but rather a steam trap, and wasn't appropriate for venting a single pipe main.
It's intended purpose is to be used as an air vent on steam systems including single pipe systems.
2 -
I wouldn't let a tech like that back in my house.
Some companies have a rule about only installing parts that they provide.0
I have had to replace the o-rings on 4 of mine when they started leaking. They were all from early batches, the o-rings were not the same as what are on the more recent ones I added to the system.0
I’m sure they do! I have some rules tooEBEBRATT-Ed said:Some companies have a rule about only installing parts that they provide.NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 120 Geothermal
