Electric furnace help
homers12
Member Posts: 1
I have a revolv electric furnace that is not
Heating. Checked the limit switch and Heating element. Both passed continuity. No shorted wires. I am stumped... help
checked the thermostat? Does it work? Need new batteries/Br. Jamie, osb
Can you post the furnace wiring diagram. Do you have a electrical test meter and know how to use it?0
Did you check continuity on the limits with the wired disconnected?
Did you check continuity on the elements with the wired disconnected?
elements should get some resistance
limits should get no resistanceEdward Young Retired
