Electric furnace help
I have a revolv electric furnace that is not
Heating.  Checked the limit switch and Heating element.  Both passed continuity.  No shorted wires. I am stumped... help
    Jamie Hall Member Posts: 27,618
    checked the thermostat? Does it work? Need new batteries/
    EBEBRATT-Ed Member Posts: 20,646
    Can you post the furnace wiring diagram. Do you have a electrical test meter and know how to use it?
    EdTheHeaterMan Member Posts: 12,583
    edited October 2023
    Did you check continuity on the limits with the wired disconnected?
    Did you check continuity on the elements with the wired disconnected?
    elements should get some resistance
    limits should get no resistance
