Today I learned something about PEX
CBRob
CBRob Member Posts: 291
Well, yesterday...
We are laying down the PEX trying to get 4 equal size zones for driveway heat.
Kept looking at the roll that was left wishing I knew how much was left.
My helper says it would be cool if they wrote it on the tubing.
Looks at the tubing and says " there is 140 ft left boss"
Lol.
Good to know.
ethicalpaulSuperTech
  • Intplm.
    Intplm. Member Posts: 2,821
    Excellent.
    Forgot all about that it is written on the coil. I looked at a coil of PE this past week and it was on there too.
  • GGross
    GGross Member Posts: 1,733
    If you tie down to rebar like that very often look into getting a pexgun wire tie tool, they are awesome! In my opinion they are much easier to use than a ton of zip ties
  • CBRob
    It was a ton of zip ties!
    Fortunately kneeling on foam
  • GGross
    That pexgun has an optional extension so you can do most of the ties while standing. We rent them out locally not sure if your local supplier might do the same. They are a bit pricey, but well worth it in my opinion
    https://www.youtube.com/watch?v=XEGTljfxFX8
    video is sped up a bit, but the tool ties really quickly
    CBRob
  • CBRob
    GGross said: very cool!!
    Expensive though, if I start doing more of these it'll be worth it.
    That pexgun has an optional extension so you can do most of the ties while standing. We rent them out locally not sure if your local supplier might do the same. They are a bit pricey, but well worth it in my opinion https://www.youtube.com/watch?v=XEGTljfxFX8 video is sped up a bit, but the tool ties really quickly
  • MaxMercy
    MaxMercy Member Posts: 552
    "Driveway" heat? Nice.
