I can’t figure out how to turn the heat on
MelCre
MelCre Member Posts: 1
Hello,
I am a newbie and just purchased a new unit. I am unable to figure out how to turn on the heat. I checked every valve and they all seem to be turned on. The water does not flow through the pipes. The thermostat is working but indoor temperature is not the same as displayed. I am attaching some pictures here. Somebody please help and please provide some inputs. Thanks
  • neilc
    neilc Member Posts: 3,164
    I see the power on at the water heater,
    is there another switch for the airhandler on the left?
    are all your breakers on ?
    are there radiators and or baseboard in your unit?
    known to beat dead horses
    pecmsg Member Posts: 7,020
    MelCre said:
    Hello,
    Where is the installing contractor?
  • STEVEusaPA
    Has to be the OP. If a so called professional did that, time to get a lawyer.
    Thats why I asked!
    HVACNUT Member Posts: 7,403
    Hydro coil off of a water heater?
    Is the fan running? Are those white pex pipes hot?
