I can’t figure out how to turn the heat on
MelCre
Member Posts: 1
Hello,
I am a newbie and just purchased a new unit. I am unable to figure out how to turn on the heat. I checked every valve and they all seem to be turned on. The water does not flow through the pipes. The thermostat is working but indoor temperature is not the same as displayed. I am attaching some pictures here. Somebody please help and please provide some inputs. Thanks
I see the power on at the water heater,
is there another switch for the airhandler on the left?
are all your breakers on ?
are there radiators and or baseboard in your unit?known to beat dead horses0 -
Where is the installing contractor?MelCre said:Hello,
I am a newbie and just purchased a new unit. I am unable to figure out how to turn on the heat. I checked every valve and they all seem to be turned on. The water does not flow through the pipes. The thermostat is working but indoor temperature is not the same as displayed. I am attaching some pictures here. Somebody please help and please provide some inputs. Thanks0 -
Has to be the OP. If a so called professional did that, time to get a lawyer.pecmsg said:
Where is the installing contractor?0 -
Hydro coil off of a water heater?
Is the fan running? Are those white pex pipes hot?0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
