Where to Put main vent ?
G_thehelpernyc
Member Posts: 3
this last picture shows a "main" atop that left most tee,
is there another in those back dark shadows ?
this main is too small,
I see a bushing, which when removed, could fit a larger vent,
what's in the shadows?known to beat dead horses0 -
and have you looked at the tops of those risers?
could / should be vents up there,known to beat dead horses0 -
Could be a puddle, but when you have plenty of Steam Available its going to blast in to the puddle & past it toward the point of lower pressure, the rad or main vent. Mad Dog 🐕1
This. If you can put some good big main vents at the tops of the risers, you almost certainly will see an improvement.neilc said:and have you looked at the tops of those risers?
could / should be vents up there,Br. Jamie, osb
You may need to drill and tap to put vents on. You probably could use vents on the tops of the risers as well. Probably was designed for coal originally so it probably had few if any vents.
If you could post a sketch of the piping in the picture and mark where the pipes go it would be easier to decide where to put the vents.1 -
So each side the building has 3 riser coming off the main. One 2 inch for the bathrooms running straight up . Another running straight through the bedrooms and suppying a radiator on other side of wall in kitchen. The third riser runs straight up Also straight pipe on one side and supply radiator on other side of wall. The 2 riser are exposed on the last floors and have Gorton D radiator vents tapped on the pipe. The 3rd riser on the last floor changes instead being straight pipe in bedroom is instead supplying 2 radiator back to back rooms-1
Looks like the main in your first pictire is setup parallel flow with an existing main vent at end of the main extension. Easy enough to increase that venting but that only addresses 30 ft in a 5 story building. The other main probably would require drill and tap. As @nelic and @Jamie say biggest improvement would be if can get main vents at the top of the risers.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
