SPACEpak blower fan runs constantly.
Fan runs constantly even when thermostat is offbor unplugged.
    EBEBRATT-Ed Member Posts: 20,094
    Sounds like a short in the wiring or a relay or contactor that is mis wired or stuck closed.
  • PC7060
    PC7060 Member Posts: 1,787
    edited October 2023
    What model and series?  I recently had a sticky/stuck TE solid state relay on spacepak 2 stage blower main board (upper right corner) .  New relay fixed the problem. Downside is having to pull the board to make the repair.
    mattmia2 Member Posts: 16,526
    Are you sure that's solid state? it looks like a pretty standard electromechanical relay to me.
  • ratio
    ratio Member Posts: 4,219
    Am open limit could make the blower run continuously as well.
  • PC7060
    @mattmia - you are correct.  Don’t know why I said solid state.  I tested that it was sticking by tapping it with a screwdriver. That’s not something a solid state would respond to.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    Soldered in relay, you simply changed that?
  • PC7060
    Yes, we have pretty good soldering stations at my work.
    You could do it with an iron in a fire if you had to.
    HVACNUT Member Posts: 7,415
    I couldn't.
  • PC7060
    edited October 2023
    Not I, too many irons there already!
    JUGHNE
