SPACEpak blower fan runs constantly.
Fan runs constantly even when thermostat is offbor unplugged.
    EBEBRATT-Ed Posts: 21,420
    Sounds like a short in the wiring or a relay or contactor that is mis wired or stuck closed.
  • PC7060
    PC7060 Posts: 1,985
    edited October 2023
    What model and series?  I recently had a sticky/stuck TE solid state relay on spacepak 2 stage blower main board (upper right corner) .  New relay fixed the problem. Downside is having to pull the board to make the repair.
    mattmia2 Posts: 18,508
    Are you sure that's solid state? it looks like a pretty standard electromechanical relay to me.
  • ratio
    ratio Posts: 4,358
    Am open limit could make the blower run continuously as well.
  • PC7060
    PC7060 Posts: 1,985
    @mattmia - you are correct.  Don’t know why I said solid state.  I tested that it was sticking by tapping it with a screwdriver. That’s not something a solid state would respond to.
  • JUGHNE
    JUGHNE Posts: 11,664
    Soldered in relay, you simply changed that?
  • PC7060
    PC7060 Posts: 1,985
    Yes, we have pretty good soldering stations at my work.
    You could do it with an iron in a fire if you had to.
    HVACNUT Posts: 7,851
    I couldn't.
  • PC7060
    PC7060 Posts: 1,985
    edited October 2023
    Not I, too many irons there already!
    JUGHNE
