SPACEpak blower fan runs constantly.
Westwood1
Member Posts: 1
Fan runs constantly even when thermostat is offbor unplugged.
Sounds like a short in the wiring or a relay or contactor that is mis wired or stuck closed.0
What model and series? I recently had a sticky/stuck TE solid state relay on spacepak 2 stage blower main board (upper right corner) . New relay fixed the problem. Downside is having to pull the board to make the repair.
Are you sure that's solid state? it looks like a pretty standard electromechanical relay to me.0
Am open limit could make the blower run continuously as well.0
Soldered in relay, you simply changed that?0
- 123 Chimneys & Flues
