Searching for a Digital Line Voltage Thermostat
One of my customers has an older radiant system with two wires to his thermostat - line in and load out. No neutral wire.
He wants to change to a non-programmable, digital thermostat and I can't find any available that don't need to be powered, i.e. a neutral wire. So, it will be battery powered, but I can't find any. Suggestions appreciated.
  • ratio
    ratio Member Posts: 4,235
    Is there a ground in the box...
    HVACNUT Member Posts: 7,440
    I'm not sure if they're still available, or even the same name, but Lux had a digital line volt (120 or 240 volt) that took AA batteries for switching. No neutral needed.
    The ones I used were programmable though.
    EBEBRATT-Ed Member Posts: 20,166
    Honeywell has an electric heat thermostat digital that worked on 240 volt. Not sure about 120 volt and it's programmable
    How about a non programmable 24 volt stat add a transformer and a relay. You could use the 120volt cable and pigtail on some 24 volt cable
    realliveplumber
    Alan (California Radiant) Forbes Member Posts: 4,719
    edited October 2023
    No
    Yes, that's plan B.
  • dko
    dko Member Posts: 669
    LuxPro PSPLV512
    pro.luxproducts.com/psplv512/
    it is programmable, but I don't think there is another option out there- at least name brand.
    but simple enough design to not be bothered by programmable controls
  • Thanks @dko and @HVACNUT! That's exactly what I need!
