Searching for a Digital Line Voltage Thermostat
Member Posts: 4,805
in Gas Heating
One of my customers has an older radiant system with two wires to his thermostat - line in and load out. No neutral wire.
He wants to change to a non-programmable, digital thermostat and I can't find any available that don't need to be powered, i.e. a neutral wire. So, it will be battery powered, but I can't find any. Suggestions appreciated.
Is there a ground in the box...0
I'm not sure if they're still available, or even the same name, but Lux had a digital line volt (120 or 240 volt) that took AA batteries for switching. No neutral needed.
The ones I used were programmable though.0 -
Honeywell has an electric heat thermostat digital that worked on 240 volt. Not sure about 120 volt and it's programmable0
Is there a ground in the box...NoHow about a non programmable 24 volt stat add a transformer and a relay. You could use the 120volt cable and pigtail on some 24 volt cableYes, that's plan B.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
LuxPro PSPLV512
pro.luxproducts.com/psplv512/
it is programmable, but I don't think there is another option out there- at least name brand.
but simple enough design to not be bothered by programmable controls
