Making a 180 for the return pipe in fintube baseboard
DustyG
Member Posts: 4
If installing a return pipe inside of a fintube baseboard, how do you make the 180 from the finned tube to the return pipe. They are so close together.
The top return ties into the element with a street el and a ninety . If running Pex for the return , run copper for the return through the base board and add the Pex adapter at the busy end . With the extra expansion of heat Pex you will hear it snake across the element ....
I remember that SlantFin baseboard has a vented U-Bend
I don't know where to get them now but I have had success with 2 street (or slip) 90° elbows inserted into the bell end of the baseboard element, or a standard and slip on the regular end of the element
I wonder if anyone online here knows the part number for it?
I guess that they didn't sell enough of them so they stopped ordering them the fitting manufacturer. Oh well!
Looks like you are stuck with the ole standby double elbow option.
Same on the vented one https://www.pexuniverse.com/slant-fin-101-024-cented-return-bendEdward Young Retired
Lots of options on Amazon. I think Nibco and Muller still make 180 bends. Not sure how close they turn?Bob "hot rod" Rohr
Living the hydronic dream2 -
Slant Fin had all kinds of neat angle fittings and those elongated, corrugated copper beads mad Dog 🐕0
A refrigeration supply house should have (or be able to get) u bends. Remember that refrigeration pipe is ordered by OD, so ½ plumbing copper is called ⅝.0
It would be 7/8"....
A "U" will bring the return too high...There was an error rendering this rich post.
- 117 Geothermal
