Kettling & Percolation Burnham NG Boiler
Docfletcher
Docfletcher Member Posts: 490
edited September 2023 in Gas Heating
My Sister's boiler. new boiler is on the way. My question is would the clogged heat exc hanger also cause short cycling? My thoughts are yes because the heat exchanger would not be able to dissipate the heat as it should. Please shed some light on the matter. Thanks
    Jamie Hall Member Posts: 26,722
    It might, depending on where the boiler temperature sensor is.
    Steamhead Member Posts: 18,173
    Is this a steam or hot-water system?
    Consulting
  • Docfletcher
    Hot water baseboard
  • Docfletcher
    I would have tried to clean it, but I think it might leak if I do.
    hot_rod Member Posts: 26,424
    Clogged or even a heavy scale from hard water will cause that noise
    Also efficiency takes a hit and short cycling can be a symptom
    How us the boiler sized to the radiators attached. Oversizing is a common occurrence in those order systems
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,370
    I like that word, "kettling"   is that A British term?  Mad Dog 🐕
  • Docfletcher
    Well, as it turns out they decided not to get the new boiler. They are running the old one for the season. My thoughts were for replacement as it is from 1993. They don't have hard water but they had several insidious leaks that were neglected for years. I got the leaks fixed, and replaced the expansion tank that had a hole in it's side.
    Baseboard, and somewhat oversized.
