combustion analyzer
I have used testo not a fan used crowcon not a fan.
Bacharach has always been accurate for me. Just make sure you keep up with the service and calibration. Mad Dog 🐕2
What is the basis for your not trusting the results?Jalen_Jalen2006 said:Find myself constantly doing Combustion tests and not trusting the #s on my equipment. I've been burned before by it what brand of Combustion analyzer would you guys recommend hands Down?2 -
Were you up to date with the calibrations?0
I use Testo, and compared to the Wohler I started with its great! I saw a guy the other day with an E com and it looked pretty good. I would buy that one as wellTom
Montpelier Vt0 -
I'm using the Testo 300 right now and I'm happy with it. (Expensive printer sold separately) Previously used the 310 and didn't like the display and didn't like to play nice when it was cold out sleeping in the van.
I've also been happy with Wohler. Don't remember which model, and the E Instruments BTU-1500 is nice too.
What are you using now and what don't you trust? Are you running the test until the stack temperature levels out?0 -
The combustion analyzer my father in law used was a stack thermometer. After the measured the stack temp., he would wipe the stem on a white paper towel. That was the smoke test. If there was too much black on the paper towel then it needed more air. I don't think flame retention burners were invented yet, do just about every oil burner has at least a #1 smoke.
He didn't like that new fangled cad cell control either. Sometimes you can't teach an old dog new tricks.Edward Young Retired
4 -
I don't know why you suspect your equipment, but my buddy is an ace tech, and he keeps an old wet kit on his truck in case something seems off with his Testo.Jalen_Jalen2006 said:Find myself constantly doing Combustion tests and not trusting the #s on my equipment.
That's kind of like the caveman's combination weather station and clock: a rock outside his cave. When the rock is wet, it's raining. When the rock is white, it's snowing. When you can see the rock, it's daytime. When you can't see the rock, it's nighttime.EdTheHeaterMan said:The combustion analyzer my father in law used was a stack thermometer. After the measured the stack temp., he would wipe the stem on a white paper towel. That was the smoke test. If there was too much black on the paper towel then it needed more air. I don't think flame retention burners were invented yet, do just about every oil burner has at least a #1 smoke.
He didn't like that new fangled cad cell control either. Sometimes you can't teach an old dog new tricks.4 -
Nobody likes my Bacharach no more, heh, ? Always works well for us. Mad Dog 🐕1
Picked up a Sauermann 130 last year and have been pretty happy with the features. Has a app for your phone and can be used with Measure Quick app for gas
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
There's a lot of people like that in the world.EdTheHeaterMan said:The combustion analyzer my father in law used was a stack thermometer. After the measured the stack temp., he would wipe the stem on a white paper towel. That was the smoke test. If there was too much black on the paper towel then it needed more air. I don't think flame retention burners were invented yet, do just about every oil burner has at least a #1 smoke.
He didn't like that new fangled cad cell control either. Sometimes you can't teach an old dog new tricks.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I'm still using my Insight Plus. Never had a problem with it.Mad Dog_2 said:Nobody likes my Bacharach no more, heh, ? Always works well for us. Mad Dog 🐕
I had a Testo, and a UEI (keep as backup).There was an error rendering this rich post.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
