Brass Inside, or Brass Outside? Do You Prefer Male or Female?
gotgas
gotgas Member Posts: 96
Let's limit this to a plumbing discussion, the title notwithstanding.
I am going from 1in schedule K copper pipe to 1in Pex A. I can use either a male or female brass sweat adapter. I have asked about this but to do not have a consistent answer.
Should the brass be inside the copper, or the copper inside the brass. Male or female adapter? Also, for what reason?
I appreciate any knowledge you can lay on me regarding this.
    EBEBRATT-Ed Member Posts: 20,155
    Brass to copper will work either way. Not an issue.
    The issue is when connecting plastic like PVC to copper where it's best to use a female copper adapter with a male on the PVC. On a job with high pressure flanges are used.
    pecmsgLarry Weingartengotgas
    hot_rod Member Posts: 27,416
    If it is hard copper tube, a Sharkbite type fitting could be used. The of both tubes is the same. Non threaded connections needed.
    There is a sweat X pex adapter available also. Which eliminates the threads.
    If it is soft K copper, a flare fitting is preferred.
    gotgas
    mattmia2 Member Posts: 16,693
    I use whichever combination costs less.
    CLambgotgas
