Brass Inside, or Brass Outside? Do You Prefer Male or Female?
gotgas
Let's limit this to a plumbing discussion, the title notwithstanding.
I am going from 1in schedule K copper pipe to 1in Pex A. I can use either a male or female brass sweat adapter. I have asked about this but to do not have a consistent answer.
Should the brass be inside the copper, or the copper inside the brass. Male or female adapter? Also, for what reason?
I appreciate any knowledge you can lay on me regarding this.
If it is hard copper tube, a Sharkbite type fitting could be used. The of both tubes is the same. Non threaded connections needed.
There is a sweat X pex adapter available also. Which eliminates the threads.
If it is soft K copper, a flare fitting is preferred.Bob "hot rod" Rohr
Living the hydronic dream1 -
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
