grohe smart " stupid box"
mikedo
mikedo Member Posts: 301
installing my first and last stupid box. got my **** kicked went online only to find out volume control dose'nt actually work. since i try to have the plumbing i install it that i want to have it work when i leave. instructions are useless only pictures no words. tech support even worse all plastic broke already. does anyone have installed them and had a good experience
Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,552
    90s Grohe & Hans Grohe WERE high quality in the late 1980s, but got "competitive" more plastic..In the early 90s.  I'm a Kohler guy or some of the real high end stuff like Dorn Beach and custom brass places.  Mad Dog 🐕
  • mikedo
    kolher does not have a shower valve you can control water voulme
  • realliveplumber
    realliveplumber Member Posts: 354
    The race to the bottom is about over. Its all junk. We installed a couple of Rohl rough in valves last week. No instructions, no markings to indicate depth in the wall.
    Moen is complete garbage.
    Kohler isnt much better.
    Jamie Hall Member Posts: 27,391
    This gadget? https://www.grohe.us/Diverter-Valves-Trims/Universal-Rough-In-Box/GROHE-NO-FINISH-35601000
    What controller are you trying to use with it?
  • Intplm.
    Intplm. Member Posts: 3,030
    Symmons shower valves. So far so good. Have repaired and installed thousands. They are the inventors of anti-scald technology that all other companies use now. Not exaggerating. Use them with confidence.
    realliveplumberGrallertdelcrossv
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    edited August 2023
    I have installed Grohe Rapido and haven't had any problems. There are a bunch of videos on You Tube to help you do it correctly.
    Plastics have become an important method of keeping prices low and competitive. You can thank your local inflation creator for the trending 'make it cheaper' and give it a one year warranty business model. Expected replacement???--One Year and a Day!
    Intplm.
  • mikedo
    still waiting from a call back from tech support only taking 2 days if they actually call me tommorrow
  • AndythePlumber
    AndythePlumber Member Posts: 111
    I’m currently installing a Grohe Smart Control. It has this eccentric adapter that I would like to talk about when I have more time I will check back to see if you’re all still here and interested. There doesn’t seem to be much out there about this and after 20 years in the business I’ve never seen this nonsense.
    THINK
  • Gsmith
    Gsmith Member Posts: 444
    Just a homeowner here, but pretty experienced do it yourselfer/mechanic. Last spring I installed the Grohe Rapido smart box and a two nob shower control (diverter/volume top knob; temperature bottom knob). It was kind of challenging but after going through it, after almost a year's use it works pretty well. I found the "pictures" instructions were tough to follow, but if you persist they are pretty accurate. The installation videos are really quite good. I did have some trouble getting the threaded plumbing to Rapido box to seal without leaking using just teflon tape, in the end I had to use both tape and brush on thread sealant. I did get rapid telephone help using he call in line and the person on the other end was quite knowledgeable. Overall I'm happy so far with the installation, but I remember thinking that if I was a plumber and had to do this for the first time (cause homeowner picked the fixtures) it would take a lot of time to learn and a challenge to bill for all the learning time; and thinking that it would be helpful to hire a plumber who had specifically installed some of these prior to me, so I didn't bear the cost of education.
  • psb75
    psb75 Member Posts: 1,132
    Gsmith, thanks for your helpful homeowner's perspective. Indeed, it is not uncommon for clients to hire us and surprise us with an unfamiliar brand of hardware (thanks, internet). I have rejected some "Asia/Euro-devices" that I couldn't/wouldn't connect to the house. If I am able to give input before the brand decision is made I tell them to stick with major, recognized U.S. brands Kohler, Moen, Am. Stand., Symmons, etc. That alone gives them hundreds of thousands of options.
  • AndythePlumber
    this is my gripe with grohe on this one. The eccentric adapter with “stippled” threads. I don’t know how else to describe them. That’s how they come though. For what purpose I can’t imagine. Then they send you about 2 feet of the thread sealing cord (loctite 55) that you “need to use” the threads aren’t tapered like a standard npt. Why is this engineered into it? I look very closely at my work, maybe this doesn’t trip up too many people. In my area at least most guys wouldn’t even notice the thread sealing cord and just use regular tape/dope. The house I’m installing this in is the nicest I’ve ever worked in. It’s directly over a magnificent great room filled with suits of armor and artwork(straight out of a movie type thing) I can’t afford a leak.
    Also- I roughed my drop ears in the wall perfectly level and at the specified center line dimension. I really struggled with the eccentric adapters to find a position where they would be level with one another and be the correct distance apart. I’ve installed many many wall mounted faucets or mop sink faucets or whatever you call them in your area and never had this issue. Just want to get this info out on the internet and possible help someone else
    THINK
  • psb75
    Sending you lots of sympathy @AndythePlumber. I don't know what those stippled threads are for. Never seen them before. That photo doesn't make me a fan of Grohe or …his brother "Hans" (That is some nice carpeting those fittings are laying on!). I will also mention that I am not a big fan of Rohl.
  • Graham_2024
    Graham_2024 Member Posts: 5
    I had trouble getting the weird threads to seal and customer service told me that threads like this are common in Europe as they use a fabric like, hemp sealing tape.
    Derheatmeister
  • AndythePlumber
    thanks for the sympathy. They put a man on the moon, I will get the done. Clear carpet tape is difficult to see in the picture, it’s there though😂. Graham I believe you are correct, but why? It’s 3” from a perfectly good npt. Anyone have experience with X-pando? I’d like to finish this installation today and I don’t have any more of the loctite 55. Amazon is about a week out for it and no one in town stocks it
    THINK
    hot_rod Member Posts: 27,489
    That is a hemp thread. The knurling is to better grab and hold the hemp.
    Loctite 55 thread is a little easier to use. Some pipe dope helps, but is not used by the true hemp pros :)
    Screenshot 2025-02-26 at 7.56.53 AM.png Screenshot 2025-02-26 at 7.56.46 AM.png
    mattmia2 Member Posts: 16,852
    that style thread is standard in europe
  • delcrossv
    delcrossv Member Posts: 2,204
    edited February 2025
    Yep. Had a 60 year old one in my mom's house. Still working. Excellent valve.
    Intplm.
  • mikedo
    the problem i had with the symmons tub and shower valve is that it is designed to allow some water to still leak out of the tub spout when being used.hard to convince a homeowner to pay you when the valve dosent work. just my opinion.
  • delcrossv
    Never bothered me, but if someone is picky, add a diverter.
  • Intplm.
    This isn't a problem exclusive to Symmons. However. Symmons shower valves are extremely reliable and repair better than any other I have seen. The spout drip on a Symmons is a repair that takes well with a high success rate. Other shower valves…not as much.
    delcrossv
  • Graham_2024
    According to Hahnsgrohe tech service and several successful installs you don't need the hemp tape or Loctite 55. A few extra wraps with tape, some pipe dope and it will be leak free.
  • mikedo
    the valve is desighed to let some water drip from the tub spout while the shower is running. at least that is what i was told by tech support
    Intplm.delcrossv
  • mikedo
    ive solved all my problems with grohe faucets i refuse to install them
    delcrossv
