Williamson Boiler Cast Iron Block Help
extremenovice
Member Posts: 14
My Williamson model Williamson GWC-105-N-T-52 gas boiler is leaking. Had a tech out and he said the cast iron block is cracked (I think that is what he called it). I called Williamson and they don't make the part anymore (boiler installed 9 years ago). Can I use a different manufacturers part? Any guidance is appreciated. Thank you
Hello @extremenovice,
Well, seems the cast Iron heat exchanger has a 20 year warranty. 9 years ago was there a 20 year warranty ? Maybe you need a second opinion as to what is actually leaking, or a lawyer if the warranty needs honoring.
https://www.williamson-thermoflo.com/sites/default/files/field-file/GWC - Gas Water Condensing Residential Warranty 0718_0.pdf
One Pipe System1 -
This might be the same as the Weil-McLain GV boiler:
https://www.weil-mclain.com/products/gv90-gas-boiler/All Steamed Up, Inc.
Consulting1 -
I think they bought Williamson so you might be right. Those parts may work! Not sure how much labor is though. Tech said it's a terrible job to do.0
@extremenovice
Williamson does not make boilers. They buy Weil Mclain boilers and put the Williamson name on it.
Weil Mclain GV 90 looks like the same boiler and it's still made as @Steamhead pointed out1 -
That would be amazing. The lady at Williamson just said we don't make the part. We will compensate for what it would of cost and prorate the warranty. I was like so you're telling me I just have to go buy a new boiler. She said yes. I knew it didn't sound right on many levels. Any idea on labor cost to replace one of those?
Btw you all are fantastic and very much appreciated.0 -
Oh I didn't know that. Thank you for the info though!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
