Williamson Boiler Cast Iron Block Help
My Williamson model Williamson GWC-105-N-T-52 gas boiler is leaking.  Had a tech out and he said the cast iron block is cracked (I think that is what he called it).  I called Williamson and they don't make the part anymore (boiler installed 9 years ago).  Can I use a different manufacturers part?  Any guidance is appreciated. Thank you
    109A_5 Member Posts: 3,963
    Hello @extremenovice,
    Well, seems the cast Iron heat exchanger has a 20 year warranty. 9 years ago was there a 20 year warranty ? Maybe you need a second opinion as to what is actually leaking, or a lawyer if the warranty needs honoring.
    https://www.williamson-thermoflo.com/sites/default/files/field-file/GWC - Gas Water Condensing Residential Warranty 0718_0.pdf
    extremenovice
    Jamie Hall Member Posts: 27,328
    But to your question -- can I use a different block? Well, no. The block is the essential heart of the boiler.
    extremenovice
  • extremenovice
    extremenovice Member Posts: 14
    Right? The 20 year warranty is on the original paperwork.  Seems they would. Of continued to make the part for warranty purchases.  Maybe the girl on the phone was incorrect.
    CLamb
    Steamhead Member Posts: 18,470
    This might be the same as the Weil-McLain GV boiler:
    https://www.weil-mclain.com/products/gv90-gas-boiler/
    Consulting
    extremenovice
  • extremenovice
    I think they bought Williamson so you might be right.  Those parts may work!  Not sure how much labor is though.  Tech said it's a terrible job to do.
    EBEBRATT-Ed Member Posts: 20,155
    edited August 2023
    @extremenovice
    Williamson does not make boilers. They buy Weil Mclain boilers and put the Williamson name on it.
    Weil Mclain GV 90 looks like the same boiler and it's still made as @Steamhead pointed out
    extremenovice
  • extremenovice
    That would be amazing. The lady at Williamson just said we don't make the part. We will compensate for what it would of cost and prorate the warranty.  I was like so you're telling me I just have to go buy a new boiler.  She said yes.   I knew it didn't sound right on many levels.  Any idea on labor cost to replace one of those?
    Btw you all are fantastic and very much appreciated.
    We can't talk prices here.
    I would suggest trying to find a local contractor familiar with that boiler. You could also check "find a contractor" on this site.
    Also post the city you are in and someone on here may know someone they could recommend.
    extremenovice
  • extremenovice
    Oh I didn't know that.  Thank you for the info though!
