Moved radiator. Will it bang?
GregWeiss
Member Posts: 30
Fits in great with all the other piping.
Water? Steam? One Pipe, 2 Pipe, Monoflow (hopefully wasn't).There was an error rendering this rich post.
The reduced pipe size might be a problem. Can you post a pic of the radiator itself?All Steamed Up, Inc.
Consulting0 -
This is one pipe steam. The radiator always had a 1” supply coming up thru the floor.
As long as the pitch is correct, it should work fine.All Steamed Up, Inc.
Consulting0 -
Why was the size reduced on the horizontal?gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
It MAY be ok, but I'd rather see a Proper Reducing 90 degree elbow than a bushing. It could ship water up with the steam as it passes over that condensate puddle. Tell the plumber rags are cheap....wipe that dope off..neatness counts! Mad Dog 🐕0
I agree with @Steamhead it'll probably be fine
I also agree with @Mad Dog_2 someone, anyone, should wipe that excess dope off. It's only going to become much harder to do after it gets hot.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yes..Lots of unsightly piping jobs often look much worse than they actually work, including Steam headers. Mad Dog 🐕0
That runout is counterflow, or should be, so the condensate is flowing from the smaller to the larger pipe. It won't back up. That said, I would have used a reducing 90 as well.GregWeiss said:Hi Gerry. I don’t know why the plumber did it like that. Maybe they’re not familiar with steam. I don’t recall seeing bushings in my steam pipes besides at a radiator.
Consulting1
- 116 Geothermal
- 15.8K Strictly Steam
