Moved radiator. Will it bang?
Had a radiator moved for a bath remodel.  The new piping doesn’t look quite right.  Can you all advise?
Mad Dog_2
  • STEVEusaPA
    Fits in great with all the other piping.
    Water? Steam? One Pipe, 2 Pipe, Monoflow (hopefully wasn't).
    Steamhead Member Posts: 18,453
    The reduced pipe size might be a problem. Can you post a pic of the radiator itself?
    Consulting
  • GregWeiss
    GregWeiss Member Posts: 30
    This is one pipe steam.  The radiator always had a 1” supply coming up thru the floor.
    As long as the pitch is correct, it should work fine.
    Consulting
  • gerry gill
    gerry gill Member Posts: 3,084
    Why was the size reduced on the horizontal?
    gwgillplumbingandheating.com
    Mad Dog_2
  • GregWeiss
    Hi Gerry.  I don’t know why the plumber did it like that.  Maybe they’re not familiar with steam.  I don’t recall seeing bushings in my steam pipes besides at a radiator.
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,538
    edited August 2023
    It MAY be ok, but I'd rather see a Proper Reducing 90 degree elbow than a bushing. It could ship water up with the steam as it passes over that condensate puddle.  Tell the plumber rags are cheap....wipe that dope off..neatness counts!  Mad Dog 🐕
  • ChrisJ
    ChrisJ Member Posts: 17,339
    I agree with @Steamhead it'll probably be fine
    I also agree with @Mad Dog_2 someone, anyone, should wipe that excess dope off. It's only going to become much harder to do after it gets hot.
    Mad Dog_2
  • Mad Dog_2
    Yes..Lots of unsightly piping jobs often look much worse than they actually work, including Steam headers.  Mad Dog 🐕
    That runout is counterflow, or should be, so the condensate is flowing from the smaller to the larger pipe. It won't back up. That said, I would have used a reducing 90 as well.
    Consulting
