Serial Communication error
oliverl114
Member Posts: 2
What causes a serial communication error?
This is a Fujitsu mini split0
Bad connections (plugs and jacks and intermediate connectors, if any). Bad power to either the receiving or transmitting module. Bad grounds for either one. Faulty cable. As a last resort, bad modules. In that order.Br. Jamie, osb
Hello @oliverl114,
All the things @Jamie Hall stated, check the easy and obvious first. Another more illusive issue that can cause problems (but much more rare) is environmental electrical interference from a some other electrical device.
Also with some equipment the L1 and L2 have to be the same (connected through the building wiring) at all the devices. Since the communication uses them or just one of them.
One Pipe System0
