Really Weird P-Trap Config: Is This A Problem
G.C.s and Archtects kill me. They worry about losing 2" in a Proper Plumbing Wet Wall, but don't like when you "destroy" their framing! All wet walls should be 2" x 6" minimum. Mad Dog 🐕6
That they should be.Mad Dog_2 said:G.C.s and Archtects kill me. They worry about losing 2" in a Proper Plumbing Wet Wall, but don't like when you "destroy" their framing! All wet walls should be 2" x 6" minimum. Mad Dog 🐕
But let's be honest. It's 2023. All exterior walls should be 2x6 as well especially where it's cold in the winter or very hot in the summer.
Some places do have this requirement but it seems like an awful lot do not.
2 -
It is 2x4. Not load bearing, other than wall board.MikeL_2 said:0 -
I am going to stick a hose in it tomorrow and let you know how it goes.0
At very least it should have a reinforcement bracket screwed around the hole:gotgas said:
https://www.strongtie.com/miscellaneousconnectors_woodconnectors/hss_studshoe/p/hss
Not really a valid test.gotgas said:I am going to stick a hose in it tomorrow and let you know how it goes.
Hey Chris—
whether your 1-1/2” drain is ok depends on if the installer is dead or not. Can you research that and get back to us so we can know what’s acceptable? ThanksNJ Steam Homeowner.
Pretty sure anyone soldering pipe in the 40s-50s is probably deceased at this point.ethicalpaul said:gotgas said:I am going to stick a hose in it tomorrow and let you know how it goes.
Hey Chris—
Not a plumber and don't look at the MA plumbing code except for the gas section (just a gasfitter) but our condo built in the 80s has 1 1/2 to the kitchen sink, bath tub and washing machine stand pipe.
But then again they did everything cheap here.
except for the time my GF pugged the garbage disposal and the clog was downstream of the trap inside the wall there have been no issues.
But I am a water runner.
The tub on the second floor used to drain a little slow. What I do is close the drain take a shower and let the tub fill some and then open the drain to give it a good flush. works fine now. Probably not much pitch between the second floor floor joists1 -
Ed,
I have pulled so, so, so much hair out of lavs and tub drains. I hate that, it is so, so, so filthy. But, the water drains down so much better. They have these plastic hook that you can stick down the drain, but sometimes I had to pull the stopper lever out of tub drains to get a good clean.0 -
When I roughed my Master Bath, I drained my Kohler Jacuzzi in to 3" It drains like a Champ. No stoppages in 22 Yrs . Mad Dog 🐕
There was actually a brief movement to try 2-1/2" waste lines for low flush toilets. The smaller diameter carrying a deeper water to keep the solids afloat.
There is a trade tech out in Calgary, plumber and instructor Fred Bretzke has piped with glass for waste and vent piping demos.
They play around with different size piping and fitting combinations to see how wet vents, double Y and different code requirements actually work in real time.
https://mechanicalbusiness.com/2023/07/19/july-august-2023/Bob "hot rod" Rohr
Living the hydronic dream3 -
- 15.8K Strictly Steam
