High efficiency wall mount boiler diagram questions
itsbackedup
Member Posts: 37
Hi girls and guys. I'm looking to see if someone could help me with a diagram for hooking up my HE wall mount boiler. In the picture the two red circles are the feeds (one up stairs zone the other downstairs zone) the blue circles are the returns. The yellow is the fresh water feed from the house. I've been doing research and just confusing myself even more. I would really appreciate it if someone could guide me with a diagram on how it should be hooked up with two zones. Also I am clueless what the plastic "Auto water fill" is on the bottom of the unit? I do know I will need a pressure tank and who knows what else. I do have a handful of 3 way shut off valves / isolation valves. Thanks
What is your location ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Rich_49 said:What is your location ?
Michigan0 -
HomerJSmith said:The tape should be Blue Monster Gas Guard, yellow not blue.0
I have a basic question what is the model number. It looks like a tankless water heater?0
heathead said:I have a basic question what is the model number. It looks like a tankless water heater?0
Yes, their video does specify Nat gas.0
That would NOT fly in NYC or anywhere in NYS. I think Blue Monster is the best Teflon Tape on the market, but I'd NEVER use it on gas or fuel oil....no matter what "They" say. I don't even agree with the Yellow Tape, but atleast an inspector may allow the yellow tape as it IS allowed in many municipalities. Do you have a specific reason you didn't use Pipe Dope paste? Just curious? Mad Dog 🐕1
Mad Dog_2 said:That would NOT fly in NYC or anywhere in NYS. I think Blue Monster is the best Teflon Tape on the market, but I'd NEVER use it on gas or fuel oil....no matter what "They" say. I don't even agree with the Yellow Tape, but atleast an inspector may allow the yellow tape as it IS allowed in many municipalities. Do you have a specific reason you didn't use Pipe Dope paste? Just curious? Mad Dog 🐕0
itsbackedup said:
That's kinda like saying England , they're roughly the same size .Where in Michigan ?
732-751-1560
Rich_49 said:That's kinda like saying England , they're roughly the same size .Where in Michigan ?0
Is that a rebranded htp painted gray? There are diagrams in the htp manual.
Are you zoning with valves or circulators?
Does that boiler have an internal circulator?
It should probably be piped primary secondary although that isnt an absolute if it is a fire tube boiler and there are 2 relatively large zones.
Is the power cord going through a partition?0 -
To answer your question, here is a simple diagram. It shows an external boiler circulator, but your boiler may come with its own boiler circulator under the hood.
The diagram is from Caleffi's wonderful series of publications called idronics. Their publication #1 called, "Hydraulic Separation ...." is probably something you should read.
Two btu per sq ft for degree difference for a slab2 -
Another way to pipe a boiler like that. Are your zones using valves or individual circulators?Bob "hot rod" Rohr
hot_rod said:Another way to pipe a boiler like that. Are your zones using valves or individual circulators?0
mattmia2 said:Is that a rebranded htp painted gray? There are diagrams in the htp manual. Are you zoning with valves or circulators? Does that boiler have an internal circulator? It should probably be piped primary secondary although that isnt an absolute if it is a fire tube boiler and there are 2 relatively large zones. Is the power cord going through a partition?0
What model Rheem boiler do you have?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Yes, there is one pump inside the boiler and a diverting valve to switch between DHW and heating modes. It is your primary pump in the heating mode.
The manufacturer says to use primary-secondary piping to ensure proper flow through the boiler.
You can buy a Rheem primary-Secondary header to make the installation easier.
https://abrwholesalers.com/rtg20318-rheem-combi-boiler-primary-secondary-manifold-kit-drain-valves-for-easy-flushing-1-cts-with-1-1-4-cts-trunk103398
Can someone explain the cluster that is attached to the expansion tank?0
Shutoff valve, backflow preventer, fill valve with a bypass, pressure gauge and then another shutoff valve in case any of the devices between the shutoff valves need servicing.
The bypass comes in handy for purging and manually increasing the pressure if the fill valve sticks.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Shutoff valve, backflow preventer, fill valve with a bypass, pressure gauge and then another shutoff valve in case any of the devices between the shutoff valves need servicing. The bypass comes in handy for purging and manually increasing the pressure if the fill valves sticks.0
What's above the tank the fill valve or backflow preventer?itsbackedup said:
An air elimination device . A proper one , not an old school terrible air scoop which everyone plumbs improperly
732-751-1560
The diagram in the installation manual is pretty clear. Perhaps it would be in your best interest to hire someone who understands it? You will need an air eliminator, expansion tank, circulator w/ flanges, zone valves, and possibly manifolds depending on your zone requirements. You can not use the internal circulator to achieve what you're looking for here. That thing above the expansion tank is the air eliminator.1
GroundUp said:The diagram in the installation manual is pretty clear. Perhaps it would be in your best interest to hire someone who understands it? You will need an air eliminator, expansion tank, circulator w/ flanges, zone valves, and possibly manifolds depending on your zone requirements. You can not use the internal circulator to achieve what you're looking for here. That thing above the expansion tank is the air eliminator.0
Looks like I need to purchase something like this ?
https://www.supplyhouse.com/Taco-TTK-100C-PRM-1-Premium-Near-Boiler-Trim-Kit-Air-Separator-Combination-Boiler-Feed-Valve-Backflow-Preventer-4-1-2-Gal-Expansion-Tank?utm_source=google_ad&utm_medium=shopping_neutral&utm_campaign=Shopping_Neutral_Returning_users&gclid=CjwKCAjwloynBhBbEiwAGY25dMiXkVjaxDsq_u3q7KZWcn1Tdh04ffrOwVfL6a0zvjvvPsUes_6cHxoCt0kQAvD_BwE
That item you posted is a fine choiceYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
This is where I am at currently. Still need to hook up the fill water line. Need to redo the condensate line in PVC (just temp so my hot water unit works) and also need to wire everything in. Then hope I have no major leaks anywhere.
You'e got 3 - ¾ x ½ tees after the pump. I don't think you need to carry on from there; just cap the ¾" pipe otherwise you're going to mix with the return, raising the return water temperature which would reduce or stop the boiler from condensing, reducing efficiency.
The diagram above shows them connected, but only when using a pressure differential bypass valve which you certainly can add.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
You'e got 3 - ¾ x ½ tees after the pump. I don't think you need to carry on from there; just cap the ¾" pipe otherwise you're going to mix with the return, raising the return water temperature which would reduce or stop the boiler from condensing, reducing efficiency. The diagram above shows them connected, but only when using a pressure differential bypass valve which you certainly can add.0
Your tee on the supply side is not facing the right direction. You need to pipe that into the branch of the tee instead of the run. You will not have proper separation between the boiler loop and the system loop with the tees like that.0
The motor on your pump should turn down 90* . That should never really be up or down , motor should always be horizontalYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
GroundUp said:Now cut it all apart and start over. The far left tee needs to be turned counterclockwise 90*. The pump needs to rotate down 90*. And you essentially have two primary loops, so none of the zones will ever see any flow- it's just going to loop around the path of least resistance.0
Here is an example of a "best practices" primary secondary piping arrangement. The space between the tees as shrrt as possible to prevent flow to the branches. piping upstream and down to minimize turbulence under high primary flow.
Your system will work as piped, although not ideal.
Heatway, Watts Radiant built Hydro Control panels with a primary secondary, pic included, on a tee like yours. And with wide spacing and a valve between the tees! Thousands of them were installed for 10- 15 years, possibly still built that way, and while not picture perfect, they work.
The flow across or thru the tees depends on the flow rates each pump provides. In some cases there is even a portion of reverse flow across the tees. Try it and see how it works before you start over.
The pump should turn down to motor horizontal.Bob "hot rod" Rohr
How is there two primary loops? As for the pump that is on a swivel so I can twist the pump which ever direction or at you talking about rotating the whole housing itself ?itsbackedup said:
The pump motor needs to be horizontal, according to Grundfos. This will require cutting it apart or unsweating the flanges to rotate them 90 degrees. You have nothing forcing the fluid into the zones. The way you have it piped, the fluid will simply take the path of least resistance and circulate through the runs of all the tees and right back to the circ. Almost zero flow will ever reach the zones as piped. I'm not sure what @hot_rod is looking at, but it's quite literally impossible for this system to work as piped. The closely spaced tees thing would work as-is, but since you have to cut it all apart anyway to send flow through the zones and rotate the circ, it'd be wise to also fix that.2 -
GroundUp said:The pump motor needs to be horizontal, according to Grundfos. This will require cutting it apart or unsweating the flanges to rotate them 90 degrees. You have nothing forcing the fluid into the zones. The way you have it piped, the fluid will simply take the path of least resistance and circulate through the runs of all the tees and right back to the circ. Almost zero flow will ever reach the zones as piped. I'm not sure what @hot_rod is looking at, but it's quite literally impossible for this system to work as piped. The closely spaced tees thing would work as-is, but since you have to cut it all apart anyway to send flow through the zones and rotate the circ, it'd be wise to also fix that.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 968 Plumbing
- 385 Solar
- 15.3K Strictly Steam
