Cheap Pipe Threader???
2»
  • JUGHNE
    JUGHNE Member Posts: 11,527
    I recall many years ago, threading 2" galv conduit out of the back of the van using 18" pipe wrench as the vise.
    Only a couple of threads but enough to learn not to make it a habit.
    Mad Dog_2
    mattmia2 Member Posts: 16,062
    You could thread something holding it with a pipe wrench in a pinch but it really isn't stable enough to make it fun...
    JUGHNEMad Dog_2
  • JUGHNE
    edited August 2023
    I had a floor in the van raised up with 2x6's, 3 spaces.
    This helped hold the long end of the pipe, the pipe wrench vise was on the steel floor of the van.
    Actually used 2 opposing wrenches so you just push down on the top one to stabilize the lower one.
    Larry Weingarten
    EBEBRATT-Ed Member Posts: 19,914
    The best thing as @ChrisJ pointed out is an old Ridgid 65R threader. It is a geared threader so it threads easier than a standard die set. Its much easier on you or the pipe machine and you can adjust it for shorter or longer threads, And it will thread 1", 1 1/4, 1 1/2 or 2" with one set of dies
    The standard Ridgid 12R died work an electric threader pretty hard especially the 1 1/2 and 2" sizes and are pretty tough to thread with for 1 1/2 and 2" by hand
  • ChrisJ
    ChrisJ Member Posts: 17,164
    The best thing as @ChrisJ pointed out is an old Ridgid 65R threader. It is a geared threader so it threads easier than a standard die set. Its much easier on you or the pipe machine and you can adjust it for shorter or longer threads, And it will thread 1", 1 1/4, 1 1/2 or 2" with one set of dies The standard Ridgid 12R died work an electric threader pretty hard especially the 1 1/2 and 2" sizes and are pretty tough to thread with for 1 1/2 and 2" by hand
    There's no gears in a 65R that I know of.
    It's 1:1 but it only cuts 2 threads or so at a time and slowly pulls the dies outward causing the taper.  That's what makes it thread easier.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,469
    I'll dig out the stocks and dies today Obi One Kenobi! Mad Dog 🐕
  • AdmiralYoda
    AdmiralYoda Member Posts: 758
  • Mad Dog_2
    Going out to the Barn now...Yoda..Mad Dog 🐕
    @ChrisJ
    Your right I looked on Ridgid's site. The 65 threader is called a "manual receding threader". The larger threaders the 141 & 161 that do 2 1/2"-4" and up are called "geared receding threaders"
    Mad Dog_2
