Cheap Pipe Threader???
The best thing as @ChrisJ pointed out is an old Ridgid 65R threader. It is a geared threader so it threads easier than a standard die set. Its much easier on you or the pipe machine and you can adjust it for shorter or longer threads, And it will thread 1", 1 1/4, 1 1/2 or 2" with one set of dies
The standard Ridgid 12R died work an electric threader pretty hard especially the 1 1/2 and 2" sizes and are pretty tough to thread with for 1 1/2 and 2" by hand0 -
There's no gears in a 65R that I know of.EBEBRATT-Ed said:The best thing as @ChrisJ pointed out is an old Ridgid 65R threader. It is a geared threader so it threads easier than a standard die set. Its much easier on you or the pipe machine and you can adjust it for shorter or longer threads, And it will thread 1", 1 1/4, 1 1/2 or 2" with one set of dies The standard Ridgid 12R died work an electric threader pretty hard especially the 1 1/2 and 2" sizes and are pretty tough to thread with for 1 1/2 and 2" by hand
It's 1:1 but it only cuts 2 threads or so at a time and slowly pulls the dies outward causing the taper. That's what makes it thread easier.
💪0
@ChrisJ
Your right I looked on Ridgid's site. The 65 threader is called a "manual receding threader". The larger threaders the 141 & 161 that do 2 1/2"-4" and up are called "geared receding threaders"1
- 125 Chimneys & Flues
- 19 Recall Announcements
