Any guess how old this radiator valve is?
cunninghamzach
Member Posts: 19
Wow..wait for Steamhead or Dan..they'll know...I'm gonna guess 1895-1905. Mad Dog 🐕1
@cunninghamzach , more pics, please- from the other side of that "Weider" star, showing any labels on the top or side including around the shaft where the handle attaches, also what is on the radiator return connection. Once in a while we find a Vapor system (which this looks like) that has not been documented, so we started a list:
https://forum.heatinghelp.com/discussion/178152/a-listing-of-vapor-systems-that-dont-yet-appear-in-lost-art
Where is this system located?All Steamed Up, Inc.
Consulting0 -
Steamhead it was a vapor system, then they turned the house into a multi family so they split each floor with its own boiler. So it no longer is. Now that floor is just dry steam0
Only one of the radiators has a vent, why did they do that with a vapor system?0
I can't make out the markings on the valve. But there's no way steam would work with just a valve at the top. There has to be a return connection, can we see that?
That Weider thing may not belong to the heat system. So far I can't see where it would attach...............All Steamed Up, Inc.
Consulting1 -
i'm thinking that might be flat on top of the valve under the handle and someone somehow worked it up partway on to the handle.Steamhead said:I can't make out the markings on the valve. But there's no way steam would work with just a valve at the top. There has to be a return connection, can we see that?
but i also think it might just be some unrelated part someone stuck on the handle.
It is still a vapor system, it isn't going to work well if you don't treat it as such. The vent is likely because whoever cut it up didn't know what they were doing and they are filling the returns with steam so that radiator couldn't vent properly.0 -
Joe "Weider" Ahhhnold's sponsor and bodybuilding mentor and Icon...Made a Fortune selling Protein powders and Muscle Magazines, Barbells and plates. I've never seen the name anywhere else...Mad Dog 🐕0
It means "again" in german so likely not an uncommon name for germans.Mad Dog_2 said:Joe "Weider" Ahhhnold's sponsor and bodybuilding mentor and Icon...Made a Fortune selling Protein powders and Muscle Magazines, Barbells and plates. I've never seen the name anywhere else...Mad Dog 🐕
1
