can these be changed from steam to hydonic?
RayWohlfarth
RayWohlfarth Member Posts: 1,851
A friend sent me pictures of some radiators and asked if they can be converted from steam to hydronic? If so, can they reuse the control valve? Never did one of these before.
Thanks in advance
Ray
Ray Wohlfarth
Boiler Lessons
    Jamie Hall Member Posts: 26,598
    Yes. Remove the trap. May be able to keep the valve.
    But...
    WHY????? What's the matter with the steam?
  • RayWohlfarth
    @Jamie Hall I know right. The owner wants hydronic Better than a heat pump I guess
    Ray Wohlfarth
    Boiler Lessons
    Steamhead Member Posts: 18,099
    They'll never get their money back. Besides, if any pipes are run in outside walls, they're likely to freeze. And the increased operating pressure WILL cause leaks if there are any weak spots in the rads or piping.
    We've saved some of our customers a third on their fuel consumption by fixing the steam. There's no reason to convert to water.
    Consulting
    Mad Dog_2CLambDan Foley
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,345
    They need to be talked off the ledge, Ray.  As Steamhead always says, two-pipe steam is the Caddy-Lack. .of Steam Systems.  Mad Dog  🐕
  • RayWohlfarth
    Thanks @Steamhead I agree
    Ray Wohlfarth
    Boiler Lessons
  • jumper
    jumper Member Posts: 2,481
    Will the guy convert boiler? I was once involved with a multistory steam to HHW project. After statically testing at 150% of new HHW pressure safety officials reluctantly said maybe but B & M insurance said no way. Nobody asked me but I wonder how bad can hot water boiler failure be?
  • RayWohlfarth
    The steam boiler started leaking a few days and they need a new one
    Ray Wohlfarth
    Boiler Lessons
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Come on everyone! You’re all too smart to talk about steam and hydronic as if they’re not the same thing. Probably one of my biggest pet peeves…BE BETTER! 🤣😉
    JohnNYMad Dog_2
  • Mad Dog_2
    Its all Water-based Heating medium...Mad Dog 🐕
    A new steam boiler and a new hot water boiler will cost about the same. To buy. But, unless the steam piping was a real mess, the hot water installation, including tearing out about half if not all of the piping, is going to double the cost.
    A very foolish way to spend money.
    Mad Dog_2CLambbburd
  • jumper
    My recollection is what Jamie says. The steam to HHW project cost more $$$ than projected. The OP's pictures show a high end steam system.
  • RayWohlfarth
    Thank you all. I am not sure what the customer is going to do as he was talking with another contractor. I appreciate all the great comments
    Ray Wohlfarth
    Boiler Lessons
