Boiler Emergency Off Switch Removal
Beefboi99
Member Posts: 24
in Oil Heating
New homeowner here. Have an older home with an oil fired boiler. Currently there’s an Emergency off Switch above the boiler and another Switch at the top of the basement stairs.
People keep mistaking it for the basement light switch and I would really like to remove it and just use the one Switch above the boiler. Don’t really see a need for it.
Is there any kind of Code in PA that I need to have 2 switches? Can I just add a firematic above the boiler?
Here's your answer: https://www.supplyhouse.com/DiversiTech-PI393-Red-Emergency-Oil-Burner-Cover-Plate-w-white-text-4-5-x-2-75
Imagine your boiler is on fire and the blower is running spewing flame everywhere. Do you want to go downstairs to turn it off?NJ Steam Homeowner.
When I sold my house in Haverford Township, Pennsylvania, I was required by the local code official to install an oil burner emergency switch at the top of the basement stairs. The boiler dated to 1947 and originally the only switch was on the unit itself.
Pennsylvania adopted a statewide building code 15 or 20 years ago if I recall correctly. Local jurisdictions may be stricter.—
Bburd1 -
Lol I grew up in Havertown. Thanks for info I’ll just go with the red wall plate then.bburd said:When I sold my house in Haverford Township, Pennsylvania, I was required by the local code official to install an oil burner emergency switch at the top of the basement stairs. The boiler dated to 1947 and originally the only switch was on the unit itself.
Pennsylvania adopted a statewide building code 15 or 20 years ago if I recall correctly. Local jurisdictions may be stricter.0 -
That switch is there in case of emergency. Definitely go red plate. Every second counts sometimes0
Considering everything is already in place for this step of extra safety, I'd agree to at least put the switch cover to remove the nuisance. A red plate (paint it red yourself even) is a well recognized tag for firemen and repairmen alike. (or -persons)
Currently in building maintenance.1 -
On commercial jobs they usually use a "break glass station" that has a small hammer attached with a small chain. In case of an emergency you just break the glass to activate the switch under the glass.0
Not sure what code is for height from the floor the emergency switch should be, but at the top of the stairs, it should be considerably higher than the light switch. It should definitely have a RED plate. BLUE for gas.
I've had numerous calls over the years for this, even when you ask over the phone if someone mistakenly shut the switch off. "Yeah yeah, it's on. Whaddaya think I am, an idiot?"
"No, sir. That'll be $$$. Should I charge the card on file?"
Carrying the laundry basket down seems to be a popular one. Raise up the basket to see the first step, bring the basket back down and whoops.
How hard would it be to wire in a door switch? Open the door and no need to fumble for switches.0 -
Than they leave the door open and NO HEAT!HVACNUT said:Not sure what code is for height from the floor the emergency switch should be, but at the top of the stairs, it should be considerably higher than the light switch. It should definitely have a RED plate. BLUE for gas.
How hard would it be to wire in a door switch? Open the door and no need to fumble for switches.1 -
Than they leave the door open and NO HEAT!pecmsg said:HVACNUT said:Not sure what code is for height from the floor the emergency switch should be, but at the top of the stairs, it should be considerably higher than the light switch. It should definitely have a RED plate. BLUE for gas.
Or shut the door to keep the noise in the basement and walk down the stairs in the dark.0 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
