Solar
MOONSTRUCK
Member Posts: 2
Existing copper piping in a solar system with tank & accumulator .
Thinking of repairing with pex , where accessible
Watch your temperatures. Remember that PEX gets real floppy when it gets to warm, and the bursts when it gets even warmer. What is the absolute maximum temperature those pipes can reach?Br. Jamie, osb
Not for this application! Not rated for temperatures0
Hi @MOONSTRUCK , What type of solar collectors do you have? Are they the typical copper collectors in an insulated, glazed box?
Yours, Larry0 -
Stick with copper or other metallic piping
A slug of solar fluid at 309F can cause the pex or a connection to failBob "hot rod" Rohr
Living the hydronic dream0
- 15.8K Strictly Steam
