Solar
MOONSTRUCK
MOONSTRUCK Member Posts: 2
edited July 2023 in Solar
Existing copper piping in a solar system with tank & accumulator .
Thinking of repairing with pex , where accessible
    Jamie Hall Member Posts: 27,241
    Watch your temperatures. Remember that PEX gets real floppy when it gets to warm, and the bursts when it gets even warmer. What is the absolute maximum temperature those pipes can reach?
    Zman
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    Not for this application! Not rated for temperatures
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,067
    Hi @MOONSTRUCK , What type of solar collectors do you have? Are they the typical copper collectors in an insulated, glazed box?
    Yours, Larry
    hot_rod Member Posts: 27,331
    Stick with copper or other metallic piping
    A slug of solar fluid at 309F can cause the pex or a connection to fail
