Domestic Hot/Cross Connect
Zman
Member Posts: 7,609
I found a cool use for my thermal camera. This condo building had a domestic hot/cold cross-connect that gave the neighboring unit a cold shower. When I ran the shower having an issue and then turned on and off the neighbor's valve, you could see the temp across the valve drop quickly when the valve was off.
If anyone recognizes the manufacturer of the valve it would be helpful. There are no isolation stops on the valve and I don't want to turn off the whole building without a rebuild kit in hand.
Albert Einstein
Albert Einstein
Aren't the Thermal Cams awesome! I will run that past my Buddy Chris Smith at Christ Plumbing supply in New Hyde Park Long Island 🏝. He also owns Forecast Sales which makes every kind of replacement stem made.. If they don't have it, you can't get it! Standby..Mad Dog 🐕0
Chris said maybe this. U can call him tomorrow after 8am EST...He ships anywhere. Mad Dog
Chris Smith Owner 516.328.04992
- 50 Industry Classes
