Poor plumbing installation in an expensive bathroom 🚻
Looks like the wax ring wasn't even compressed. Closet bolts are rusty; I like all brass with stainless steel washers.
At least they double nutted the bolts.
The supply riser looks nice.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
not sure that is a nice bathroom. looks like someone slapped some stuff from home depot on top of what was probably a better bathroom0
The Homeowner spent 45 K on this bathroom 3 yrs ago. He hired The G.C. because he said he didn't have to call in any other trades...he would take care of it....he was a Master of all! The Tile work is excellent, Georgeous Vanity and shower. The complaint was sewer flies and dampness im front of toilet base. When I pulled bowl & looked down closet bend, I saw water looking back at me...and a pipe plug. They used a Tee Wye w a plug instead of an elbow sweep...cute...also, roughed the flange below grade and the wax ring was never "kissed" by the Toilet Horn..underneath the bowl was nasty....was able to rework and reset. Should be good. Mad Dog 🐕0
Oh no he didn't....it HAD a SS Flex (a higher quality one) but I "disappeared' it.....you won't see him no more...The HO wanted it for an emergency. The only thing that annoys me is that they put a sticker on the Upper end near the cone top and it leaves mess on the finished chrome. Its all nice, smooth and shiny except for that area. If I had denatured alcohol (I love the smell of that!) It usually removes the sticky residue. Yeah...it was a black, Stink puddle under there...a breeding sanctuary for sewer flies. I napalmed it with Isopropyl alcohol, to kill all the flies and Biohazardous swill first, sucked it out dry and, then I filled that void with a whole bucket of "Yeso de paris!!! (plaster of paris)/grout combo. If it ever rears its ugly head again, we're saw cutting and doing an amputation of the closet bend-Sanitary tee & raising the flange. Mad Dog 🐕0
I actually needed a nice brass or even plastic Tank nut for that speedy, so I stopped in a very good plumbing supply...After a 15 minute search,, They had neither. I was ready to rob it from a new ballbock box I had, but I knew I had a full jar Back in the barn. Job was 3 minutes away...took a ride. Mad Dog 🐕0
Paint thinner will take that off.Mad Dog_2 said:The only thing that annoys me is that they put a sticker on the Upper end near the cone top and it leaves mess on the finished chrome. Its all nice, smooth and shiny except for that area. If I had denatured alcohol (I love the smell of that!) It usually removes the sticky residue.
Then paint thinner to take the wd40 off. But coating with oil is good to get dried out adhesive off. Vegetable oil or shortening works too.ChrisJ said:
I find it interesting that most diyers and some inexperienced contractors don't understand that a bowl gasket isn't meant to get wet - a bowl gasket can get wet when there is a blockage & backup in the connected soil pipe below the toilet.
Fine Homebuilding magazine published an article titled " Trouble free toilets " several years ago. It's a short read that I steer my customers to so they'll understand why I insist on a more costly permanent repair for a low flange & spongy underlayment.
I've seen many hundreds of stacked bowl waxes under toilets that create some nasty hidden damage. Stacked waxes make it difficult to provide & maintain sanitation.
I tend to agree, but ya give it one good shot...it happens again, were sawcutting and chopping the new tile up. If the flange were a little lower than that, you/they got a problem. I still can't get over the fact this guy used a Sanitary tee..... Mad Dog0
There are some great repair products,but this wasn't that bad. Stephen...tell me about these waxless rings. I've used Wax-impregnated FELT gaskets, especially for Backoutlet bowls. Repairing an old lead bend with 50/50 bar solder is fun..Mad Dog 🐕0
1
Rubber! Just like urinal and Chair carrier gaskets....cool...Mad Dog 🐕0
I have used these in my home because of this very reason--they seem to (my untrained self) to solve this issue and work well...FStephenMasek said:The new no-wax rings are mighty handy. Wax rings tend to fail if you move the toilet after putting it down (typically to get it centered/straight left to right).
so therefore I assumed that actual plumbers must hate them. Is that the case, or do plumbers think they are good?NJ Steam Homeowner.
I have used these in my home because of this very reason--they seem to (my untrained self) to solve this issue and work well... so therefore I assumed that actual plumbers must hate them. Is that the case, or do plumbers think they are good?
I don't use csst, won't use shark bites, still solder copper, and don't like pvc for venting flue gasses.
I do use pex, and will use a flexible bowl gasket, mostly during bathroom remodels when a toilet has to be set & reset.2 -
There comes a time, when you don't have much choice, its 10 pm...they need a toilet or heat and you do what u gotta do..If something is iffy, I'll go back and do the proper repair the next day. Never left a Fernco coupling on permanently...just can't do it...Mad Dog 🐕 🤣
How else would you connect PVC to cast iron?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
caulk it with lead and oakum.ChrisJ said:Mad Dog_2 said:There comes a time, when you don't have much choice, its 10 pm...they need a toilet or heat and you do what u gotta do..If something is iffy, I'll go back and do the proper repair the next day. Never left a Fernco coupling on permanently...just can't do it...Mad Dog 🐕 🤣
How else would you connect PVC to cast iron?0 -
I would trust a shielded coupling more my self.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
No-Hub Coupling...has the full shield a Fernco is rubber with two large Hose clamps...not Rat proof...Mad Dog 🐕0
Not all of them.Mad Dog_2 said:No-Hub Coupling...has the full shield a Fernco is rubber with two large Hose clamps...not Rat proof...Mad Dog 🐕
https://www.fernco.com/products/shielded-couplings
2 -
I had a feeling that's what you meant after thinking about it for a bit.Mad Dog_2 said:No-Hub Coupling...has the full shield a Fernco is rubber with two large Hose clamps...not Rat proof...Mad Dog 🐕
So something like this.
From Top to bottom: Here in the "Big City,"
We call em the following
- A Fernco
- A Husky 4 bands (Legal underground)
- A Clamp All ( Full Shield higher torque)
- a No Hub Coupling
- A Mission Clamp (Full shield, reg torque
High quality clamp for reduction in pipe size. They make all different sizes...
Mad Dog 🐕0 -
Before Huskies came out, we occasionally used No Hubs and PVC underground for a repair or if the folks couldn't afford Service Weight or MG Couplings. Mad Dog 🐕0
Thanks Larry...yep...seen em chewed right through in the Housing project crawl spaces. They are great for a temp fix. Huskies are much stronger but I've still seen them blow apart with 4 stories of W.C. test on em...I watched a 12" Coupling creep apart over 30 seconds...Man that was alot of water! Mad Dog 🐕0
Orangeburg! is there much of that still out there?
It was used here maybe in the 50-60's until PVC came along.
IIUC, modern detergents would wash the oil out of the Orangeburg, leaving only the "paper" fiber.
Then here come the roots and the weight of the earth compaction.
The earliest PVC was thin wall and would perhaps split open under compression of bury or the tree roots would again attack.
The early solvent/glue was, unknowingly, not used correctly and the couplings would have gaps for tree micro roots which would then grow to branch size roots inside the pipe as they were well fed.
None of this compared to the clay tile we had installed in the 1930's WPA project for the entire town.
The pipe material was pretty invincible but the joint system lacked a lot....cemented spigots into the hubs, maybe every 30 inches. The cemented/tar eventually dried up and fell out.
Again, I used to look at these installations and criticize the installers for being short sighted in their work.
But, they had no previous experience of UG sewer pipes and how much tree roots were attracted.
They were pioneers in the field and people were so grateful to not leave the house in a blizzard to sit over an open pit....and freeze their parts off.
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
