Radiant manifold supply and return same temp
Davey76
Member Posts: 1
I am the owner builder but I had an experienced plumber run my radiant lines but my crew installed the actual flooring system. Similar to warm board but cheaper. My radiant supply manifold is the same temp as the return on 2 of my 3 manifolds. Does that mean the supply and return loops got mixed up ?
How about some pics?Bob Boan
Anther great question this time of year is what temp is the water and what temp is the ambient?0
If the room is warm or t-sat about satisfied you may not see much of a ∆.
Are there flowmeters at the manifold?Bob "hot rod" Rohr
