What do you make of this?
Sdress27
Member Posts: 8
Not sure what this device is. Anyone have any idea? It is attached to a steam line. Its near a coil for an AHU also near a pressure reducing valve not sure if those context clues help. Thanks
Just saw the sight glass. Can u get a pic from a way back to see what its connected to? Mad Dog 🐕0
The bottom line is going to a drain the top two appear to be part of a larger condensate line which goes to a condensate receiver/pump.
Any check valves? If u could draw a diagram of whats piped to and away from it , that would help. Mad Dog 🐕0
No check valves in immediate area0
Any name on it?
Consulting0 -
It sure looks like a float type steam trap. These would not be bubble tight but having a level of water above the valve and seat, it would be water sealed, passing only water but not any gasses.
Now, why its there, and what its supposed to do; that to me is the real question.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
Why the sight glass though? And I cant find any information on what kind or model that is to go off.0
That's probably an inventory number that the building's owner or manager put there.reggi said:Steam Trap 4721 😉 .. The stamped tag wired to valve in picture #2
The sight glass is probably there so one can see the rising and falling water level.
We have a lot of old literature- that's why the name is needed. Have you found names on any other old hardware on this system?Baltimore, MD, USA
Consulting0 -
Wire brush with on a pole extension if you can't reach.... it's just about flaked off already 😷🥽Sdress27 said:Why the sight glass though? And I cant find any information on what kind or model that is to go off.
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
I brushed it off couldnt get a good picture but it said
“Steam Trap Boylston Steam Special Chicago” I guess the mystery is kind of solved but still looking for another example on the internet or something similar. To see what it looks like inside and still fascinated by the sight glass.0 -
Well, we're always learning. I'd never heard of Boylston, but apparently they were founded in the late 19th century, and are still around. From what I can tell, they specialized in high-pressure steam specialties. I googled them and here's what came up:
https://www.google.com/search?client=firefox-b-1-d&q=boylston+steam+specialty+co#ip=1
@Sdress27 , this may have been a high-pressure system. Is it in an old factory building?Baltimore, MD, USA
Consulting0 -
Maybe @retiredguy or @Dave in QCA .. they seem to have some knowledge on Boylston ( prior posts)One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
Not the exact one as I don't see two tappings on the side- possibly for different pressure ratings as there were 5 different styles (bottom of boylston4 pic). Attached some advertisements of the boylston steam traps. along with other steam traps that used sight glasses during the same time period.4
Awesome thank you all for your contributions and assistance!0
Glad you found what you needed..still a interesting history. . But anyway here's the original design and patent... not always the final product but interesting info
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question1
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
