DZR Brasss
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,391
edited May 2023 in THE MAIN WALL
Hi. Was looking through fittings on Supplyhouse and noticed DZR brass. Are those different then "regular" brass fittings? Once we are on the topic, can someone enlighten the uninformed (myself in particular) about the different types of brass fittings/piping and their applications? Much appreciated. My particular application,is 1" FIP- 3/4" press brass fittings. To be used when installing 75 gallon water heaters. Thanks in advance to all.
Mad Dog_2
    hot_rod Member Posts: 25,268
    Dezincified brass it is an alloy that has the zinc removed
    certain water conditions were causing pinholes in common yellow brass fittings, so they changed the mix a bit
    A few lawsuits still linger out there regarding brass pinholes, mostly the pex fittings
    Lead % has been changed in brass used for potable water, see it listed as LL low lead, or LF lead free. Most brass companies are switching to low lead for potable and hydronic, pneumatic, etc
    machinery has to be retooled when you switch to machining LL, chips segregated for recycling
    Lead acts as a bit of a lubricant, removing it causes tooling to bind, over-heat…
    Mad Dog_2STEAM DOCTOR
  • STEAM DOCTOR
    Thanks @hot_rod. Need to study what you said a bit and try to digest. For my application, 75 gallon water heaters, these fittings are advisable?
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,881
    Hi, I like to use a plastic lined steel nipple in the tank, and then transition to the piping. This helps prevent any damage to the tank. In the West, flex connectors are commonly used in part because of earthquakes. Falcon makes stainless flex lines at least up to two inch. This gives both a union and the ability to make a heat trap. Then I use whatever stainless, brass or copper fittings are needed to change size … if needed. B)
    Yours, Larry
    Mad Dog_2
  • STEAM DOCTOR
    Thanks. Flex is pretty uncommon in my part of the world. Good old NYC area  Usually reserved for handymen. Not criticizing. Just saying.Most water heaters that I have seen, come with plastic lined nipples already installed. Gas atmospheric, typically 75 gallon and down, are what I deal with.
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,254
    I miss the High Qaulity Red Brass everything was made of.  Lasted forever.  85% Copper 15% Zinc.  Yellow brass is eh...The new Lead Free and LL products are much more difficult to soft solder.  The solder does not suck in,  adhere as well and fully penetrate and spread the solder.  Even the finest silver bearing solders Like Silvabrite, Taramet, Harris and Wolverine struggle.  We usually have to pre-tin large diameter fittings, especially the ball valves.  It is what it is.  Mad Dog 🐕
    PC7060clammyCTOilHeat
  • Mad Dog_2
    The cheap imported brands are even worse,  similar to Muntz metal and Pot metal....real junk.  Mad Dog  🐕
    kcoppPC7060
    The nippler Larry mentioned are often heat trapper also, a check ball or flapper inside.
  • clammy
    clammy Member Posts: 3,227
    The crappy brass is close to impossible to properly sweat ,one or two old timers I know swore they would never buy into a press fittings but after multi attempts of soldering on lead free valves given in and went press . I also have switched and use mostly press valves even though there all junk in my eyes but it super quick and no flame and I get to charge way more being everything is expensive but that’s cool more money more money more money .
    I think making the valves impossible to solder was a way to get everybody on board w press crap ,even though its all recycled it s really just throw away fittings and valves keeps some body working and producing junk the name of the game . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    Mad Dog_2
    One method that helps soldering the low lead brass, is to heat the tube as you heat the brass fitting.
    The LL brass seems to expand more and doesn’t conduct heat to the copper tube as well.
    So bring the tube and fitting up to temperature evenly.
    Lead free solder and water soluble fluxes add even more challenge. The new flux tends to burn or blacken close to the melting point of no lead solder. So temperature control is more critical.
    As long as I don’t see you using push type gripper fittings😳
    Larry WeingartenMad Dog_2
  • dko
    dko Member Posts: 668
    edited May 2023
    This is why sterling solder now outsells 95/5. Lowest melting temperature and great flow, much easier to work with on these new valves. many seem to think it contains silver, but it's actually selenium.
    Mad Dog_2
  • Mad Dog_2
    The 3 best Solders that I use are Taramet Sterling, Silvabrite and Wolverine brass.  Mad Dog  🐕
  • ChrisJ
    ChrisJ Member Posts: 16,800
    My favorite solder for a few years now is Bridgit.
    You can still find 50-50 in some hardware stores, I use it on hydronics.
  • ChrisJ
    edited May 2023
    I've never heard of 50-50?
    40-60 is the most common for electronics, 37-63 is another common one.
  • dko
    edited May 2023
    are you also using bridgit flux?
    I only recently brought in both the solder and flux
    sold only a handful but haven't any feedback yet.
    50/50 is fairly standard, still sell plenty of them. hydronic piping mainly, but dwv copper is still selling for repairs and there are plenty of guys still piping 3 compartment sinks in dwv copper.
    also still selling heaps of 50/50 lead bars for lead pans.
    ChrisJ
  • ChrisJ
    No, I didn't know there was flux.
    I've been using Oatey 95 tinning flux lately.
    pecmsg Member Posts: 6,245
    Stay Brite #8 for all my Soft Solder Needs!
