DZR Brasss
STEAM DOCTOR
Member Posts: 2,598
Hi. Was looking through fittings on Supplyhouse and noticed DZR brass. Are those different then "regular" brass fittings? Once we are on the topic, can someone enlighten the uninformed (myself in particular) about the different types of brass fittings/piping and their applications? Much appreciated. My particular application,is 1" FIP- 3/4" press brass fittings. To be used when installing 75 gallon water heaters. Thanks in advance to all.
1
Dezincified brass it is an alloy that has the zinc removed
certain water conditions were causing pinholes in common yellow brass fittings, so they changed the mix a bit
A few lawsuits still linger out there regarding brass pinholes, mostly the pex fittings
Lead % has been changed in brass used for potable water, see it listed as LL low lead, or LF lead free. Most brass companies are switching to low lead for potable and hydronic, pneumatic, etc
machinery has to be retooled when you switch to machining LL, chips segregated for recycling
Lead acts as a bit of a lubricant, removing it causes tooling to bind, over-heat…Bob "hot rod" Rohr
Living the hydronic dream2 -
Thanks @hot_rod. Need to study what you said a bit and try to digest. For my application, 75 gallon water heaters, these fittings are advisable?0
Hi, I like to use a plastic lined steel nipple in the tank, and then transition to the piping. This helps prevent any damage to the tank. In the West, flex connectors are commonly used in part because of earthquakes. Falcon makes stainless flex lines at least up to two inch. This gives both a union and the ability to make a heat trap. Then I use whatever stainless, brass or copper fittings are needed to change size … if needed.
Yours, Larry1 -
I miss the High Qaulity Red Brass everything was made of. Lasted forever. 85% Copper 15% Zinc. Yellow brass is eh...The new Lead Free and LL products are much more difficult to soft solder. The solder does not suck in, adhere as well and fully penetrate and spread the solder. Even the finest silver bearing solders Like Silvabrite, Taramet, Harris and Wolverine struggle. We usually have to pre-tin large diameter fittings, especially the ball valves. It is what it is. Mad Dog 🐕3
The cheap imported brands are even worse, similar to Muntz metal and Pot metal....real junk. Mad Dog 🐕2
The nippler Larry mentioned are often heat trapper also, a check ball or flapper inside.Bob "hot rod" Rohr
Living the hydronic dream0 -
The crappy brass is close to impossible to properly sweat ,one or two old timers I know swore they would never buy into a press fittings but after multi attempts of soldering on lead free valves given in and went press . I also have switched and use mostly press valves even though there all junk in my eyes but it super quick and no flame and I get to charge way more being everything is expensive but that’s cool more money more money more money .
I think making the valves impossible to solder was a way to get everybody on board w press crap ,even though its all recycled it s really just throw away fittings and valves keeps some body working and producing junk the name of the game . Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
One method that helps soldering the low lead brass, is to heat the tube as you heat the brass fitting.
The LL brass seems to expand more and doesn’t conduct heat to the copper tube as well.
So bring the tube and fitting up to temperature evenly.
Lead free solder and water soluble fluxes add even more challenge. The new flux tends to burn or blacken close to the melting point of no lead solder. So temperature control is more critical.
As long as I don’t see you using push type gripper fittings😳Bob "hot rod" Rohr
The 3 best Solders that I use are Taramet Sterling, Silvabrite and Wolverine brass. Mad Dog 🐕0
My favorite solder for a few years now is Bridgit.
You can still find 50-50 in some hardware stores, I use it on hydronics.Bob "hot rod" Rohr
I've never heard of 50-50?hot_rod said:You can still find 50-50 in some hardware stores, I use it on hydronics.
40-60 is the most common for electronics, 37-63 is another common one.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
are you also using bridgit flux?
I only recently brought in both the solder and flux
sold only a handful but haven't any feedback yet.
50/50 is fairly standard, still sell plenty of them. hydronic piping mainly, but dwv copper is still selling for repairs and there are plenty of guys still piping 3 compartment sinks in dwv copper.
also still selling heaps of 50/50 lead bars for lead pans.
1 -
No, I didn't know there was flux.dko said:ChrisJ said:My favorite solder for a few years now is Bridgit.
I've been using Oatey 95 tinning flux lately.
Stay Brite #8 for all my Soft Solder Needs!0
- 120 Geothermal
- 394 Solar
